AnthemBassMan
- Apr 26, 2014
- 2
- 199
Use the cheater method. Get a standard business card, loosen the two bolts for the coil. Slide the card between the coil and flywheel, then push the coil against it while tightening the bolts. You can also turn the flywheel so the magnets face the coil and that will hold the gap you need as you tighten the bolts.
L8R,
Matt
L8R,
Matt
