McTurff
Im finish up a long battle with this machine and maybe at the finish line.
After many months of trial and error I found my problem !!
This motor had a 3 screw carb which i haven't been able to get right so will keep working on it in the mean time put a 4 screw carb on and it runs but not perfect! Take air box off and it runs pretty dang good and after looking at the air box it had one hole for vent or jet to the 3 screw carb which only had one hole on top! so the other hole was being blocked for the 4 screw carb!
So probably obvious question should I drill out the other hole??
Has anyone experienced this situation!
Here are some pics
Carb no gasket with gasket and the air cleaner base!
Thanks
Here are some pics
Thanks
