- May 6, 2010
- 51
- 11,427
this may or may not be relevant. Do you have a way to do a compression test. I am wondering if this issue may be more compression related, then carb related. Low compression causing improper ignition of fuel in the cylinder. those small L head briggs engines were bad to float the intake valve.
