Hello
I picked up a Yard-Man by MTD 13AA604F401 mower from a friend for $100 a year ago, it ran great all of last year and is still running good now. It has a Briggs & Stratton 13.5HP OHV 311777 0209-E1 engine in it.
I've noticed the mower seems to be idling a little rough - So i plan to give the whole mower an overhaul e.g. tune-up, re-filling grease points, adjustments etc etc.
Planning to start with the engine, oil change, new spark, filters and so on. I'm doing this all based off of the adjustments and serviceable items specified in the manual for the engine. One item it talks about is checking the Engine's RPM when adjusting the carburetor and making adjustments as necessary. How do you actually use a tachometer on a mower engine though, don't you have to wire those up to get an accurate reading?
Page 15 of the attached manual is where it discusses carb adjustment and the RPM
Thanks,
Allan
Thanks,
Allan
