Tinkerer200
- Mar 14, 2015
- 913
In my experience the opposed twin CDIs fail considerably more often then B&S singles or V twins which use 2 coils. First you might want to install a fuel line shut off and turn the gas off a few seconds before shutting the engine off. Or you can do this by clamping the fuel line. Sometimes fuel leaks on thru float needle flooding the engine until fuel evaporates off. On some of these engines the fuel line ran thru the cooling shroud causing vapor lock sometimes. I agree that the coil mounting surfaces need to be bright clean but to ground the coil properly not for heat transfer.
Coils do fail gradually sometimes. It is common on these opposed twins for failing coils to start an engine when one plug wire is disconnected, some say when that wire is then grounded to the engine. I have not experienced that. Might try it.
Walt Conner
Walt Conner
