I have a 18.5 hp Briggs that starts and idles good but cuts out at higher rpm’s. I have cleaned the carb, and replaced the fuel pump and fuel filter. I also took out that cheap plastic cut off valve, thinking it may be the problem, but that didn’t fix it. Two videos below.
