Need help, I'm at a loss. Picked up a freebie Troy Bilt Pony rider, no history on it. Valve cover was missing, not sure if they tinkered with the valves. Starter was fried internally and carb was trashed. I had a replacement carb with a fixed air mixture screw, used it just to get it running. Replaced the valve cover, starter, fuel lines, fuel filter, new spark plug (RC12YC), oil change and new battery. It started but seemed to have too much compression and struggled to get "over the hump" but then it did crank and ran strong but it was surging.
I ordered a new carb with adjustable air mixture screw. Put the new carb on, didn't change anything else, now it is extremely difficult to get it to turn a full rotation. I took the plug out and it spun freely. It was not hydrolocked. Checked the valves, still set at .004/.006. Checked the push rods, they are both straight. After I put the plug back in I put a spark tester on and it started first crank. I turned it off and removed the spark tester and connected the plug wire and tried to start it. It backfired and then the compression was again too strong to allow the engine to turn over. I pulled the flywheel and checked the key, it was good. I have tried jumping it off the battery on my JD LX279, no difference so battery is not the issue.
Any ideas???
Any ideas???
