Mkala
- Jan 5, 2019
- 5
- 140
Hi all,
My father mower started to develop an oil leak on the rocker cover. This is an OHV 6hp briggs vertical for a Toro walk behind mower. This design is with a die cast rocker cover, then an gasket, than a rocker plate (where the studs holding the rockers are), a gasket (cylinder head style matter) and then the head. This is a 650 Intek I think, not sure with the Toro branding (190cc, and I think this head design is the same for a lot of 120000 and others - pictures below).
Last year, I replaced the rocker cover gasket and the rocker plate gasket, and the mower is still leaking (a bit less, but still a major leak). This morning we decided to disassemble again to analyze. The rocker gasket has the mark (there is an edge in the rocker cover casting) all around in it, looks like it is sealing.
The rocker plate gasket look in good shape, not crushed, but perhaps not sealing in a bottom corner. Was tightened by hand perhaps it was too low torque. Note we bent back the rocker plate last year to make it flat again, when tightening the bolts too much it can curve it.
So now I have a torque wrench, a decided to clean all surfaces, check for flatness (all looks really nice) and torque it to 10Nm for both (as it is in manual for OHV engines).
The result was even worst, as this looks way too much and crushed the gaskets :frown:
I use only brand new briggs gasket and now I have to buy them again. What can I do ? Anyone has a better idea than trying to reasselbe all again for the 3rd time, but now I think I will apply 5-7Nm instead of 10 ? Start to be a bit frustrating and tricky to have this engine oil tight (but it was for 15 years so it should be doable !)
Thanks for any advice
