- Feb 19, 2020
- 121
- 12,895
Sounds like just another person using a flex hone to do the work of a rigid hone. Just makes things worst.
If the cylinder is either ovaled or tapered (usually both) a flex just makes both these worst. Besides if you were able to hang a finger nail on grooves the cylinder should be rigid hone to .020"over as there is no .030 piston supplied anymore. If you got go over .020" then the engine is a basket case. I have seen cylinders tapered that only clean up within the last .002"
As for valve clearance on L-head (side valve) engine I always grind for the max clearance spec as the these engines tend to close up valve clearances over time. This is so I don't need to redo the valves as often. Right the opposite with OHV engine where I do the minimum settings.
