Briggs 10.5 hp carb rebuild
hilcntry
Greetings!
Have a Swisher trail mower with a manual start 10.5 Briggs.
The carb float apparently sinks and floods the engine when not in use.
Put a gas cut off in line and and only partially fixed problem.
Went to NAPA with engine nbrs and tried to get a rebuild kit and
he tells me there's 3 diff carbs for that engine.
Here's what I have--
model 28B702, Type 1113E1, code 030716ZD. date 040504
Any help in identifying rebuild kit will be appreciated.
tnx, hilcntry, Tom
LMT 92,93,94,95,96,108,111,162,165,169 use carb kit 499220. LMT 97,99,133,135,136,157,158,159,160,166,168 use carb kit 499231. LMT 63,65,66 use carb kit 497481. 696160,696162,696164,696166,697213,697213,697214,697906 use carb kit 697884. If your carb has a 6 digit number stamped into it is the carb use the kit list with the six digit carb numbers.
