bricktop has a miss
reed
my 77 model bricktop runs great but about every 20 to 30 seconds it has a miss ....other than that runs strong...what is causing this...any suggestions
Fireman 123
Have you tried to adjust the air/fuel setting? I would tighten it until it bottoms out, then back it off a couple turns. You may have to fine-tune it some from there. How does it run under a load?
reed
is that the large green knob on the carb on top
Fireman 123
Yes, that'd be it. Here's some info from the book.
reed
hopefully that will solve the annoying miiss..is this common
Fireman 123
Hopefully. In my experiences, it's not uncommon to have to work on the old lawnboy carbs. They're really simple, and replacement parts are cheap.
jmurray01
, , 1,000 Post Club
Let us know if you get it fixed.
A misfire is always annoying.
reed
just curios would the loose on off primer switch jumping around cause this miss ...have nt replaced it yet ...it has a spring on it mya be causing this hmmmm.will let yall know
Fireman 123
The bricktop has a points/condenser ignition system. I would look to see if you have any loose wire connections, or worn parts. Good luck.
reed
woohoo half a turn on carb miss is gone ..thanks again guys .runs like a beast
