Brake/pto release engine stalls
GunnerBob
RZ5424 about 15 ys old. Runs fine. Had a fuse blowing issue first. Which led to lots of new switches and parts thrown at it. Two things. Release brake engine stalls, engage pto engine stalls. Has to be a safety switch issue. Tested them all good. By passed seat switch. Engine runs well, hoping to get some assistance with a clue or two as to what to check next. Also, bench tested the PTO clutch it checks good with the multi meter and the 12-volt check. What am I missing?
How are you supposedly bypassing the seat switch? You can't jumper it or simply unplug it.
GunnerBob
of course, the battery is dead. Will charge it and plug seat switch back in and report.
