Hi All
I have a Bernard Loisirs BL14536RBH sit on lawnmower with Briggs and Stratton engine. The engine is fine but when out on a job last week the brake/clutch pedal has stuck and will not move. I like to do my own small engine repair but this problem has got me stumped. I will list the info on the problem below in the hope that someone can help me out with this:
The wheels are not locked and can still roll.
All the brake and clutch mechanism works perfectly when the wheels are off the ground but as soon as the wheels are on the floor it locks up again in the same off position.
The engine was running fine before it broke but cannot start the engine now as i need to drop the clutch to start it.
All the parts of the clutch/brake mechanism are oiled and free from mud etc.
Another problem is that the mower is stuck in a field where a tractor cannot get to it and is to far away from track to tow it out with car so it needs to be fixed where it is.
Any help anyone can give will be welcomed
Best regards
Adam
Sorry about small pic but is a generic photo just to show you the model. I will take some pics of my actual mower when i am up there next.
Best regards
Adam
