The screen in the exhaust is problematic. It will cause an abnormal amount of carbon buildup in the combustion chamber and exhaust port on the engine. This will happen even with using Stihl synthetic engine oil.
The screen is there for the machine to be 50 states emissions compliant. It is removable and many have removed it to improve the performance.
What is the compression of this engine?
Although this engine is a 4 stroke with operating intake and exhaust valves, it is a dry sump engine and needs to have mixed fuel, and you know this.
Alternate spark plugs don't work well in these engines, what spark plug do you have in this engine and what is the gap?
I removed the spark arrestor. No change. I removed the exhaust tank. No change. I have a brand new NGK 3365 CMR6H spark plug installed which is what the br600 manual calls for. (Also what came out of it from the factory) the gap is factory set at, I believe, .20 but I could be wrong there.
