PTmowerMech
- Apr 16, 2018
- 443
- 3,421
Kohler V twin. Gonna adjust the valves on it because it's not turning over very well. Kind of starts and stops turning over mid stream. The battery is charged fully.
I've had one or two of these break off. It's always the same one. Bottom right. So these two bolts (both cylinders) are tight as all get out. I haven't put anything more than a cheap 1/4 walmart brand impact on them (yet).
So before I go gorilla on it and snap it off, I'm thinking I'd better check with the experts first. I'm thinking maybe run it til it get hot, then cools down?
Anyone know any trick to this? My luck the bolt will break off below the surface.
P.S. I tried tightening and loosening. But that didn't help.
