Hi new to the form, looking foreword to giving and receiving input. I'm working on a Bolins BL100 grass trimmer for my son.He gave to me to fix a leaking gas issue,I replaced the fuel lines from the line I purchased from a repair shop, but it still leaked. I then purchased a fuel line repair kit to fit this model,fixed the leak (great) but now the problem starts. When I start it I push primer 4 time and close the choke, the trimmer starts but only idles for about 5 seconds then quits,I then put on half choke pull the cord it starts and revs up for a few seconds and quits again. I then open to all the way pull cord it revs up for a split second and quits again. I tore the carb down and cleaned it,cleaned the air filter,tried loosening the gas cap and nothing changes.Any fellow small engine techs have any idea on what I could be missing......Thanks
Torodude
Torodude
