Bolens 38" Reverse cut ?
2pups
I got my dad a Bolens rideing mower about a month ago , not sure of the model . It wont cut in reverse , I am wondering if there is a way to make it mow in reverse so he doesnt have to keep messing with the pto all the time .
Jeff
Carscw
Jeff
This is a easy fix. Not sure what model you have. Look under the forward - reverse Lever there is a switch that when you move the lever to reverse the lever hits the switch. Unplug that switch.
Some mowers all you have to do is turn the key back one spot.
(( cowboy up and get over it ))
2pups
Thanks for the info Carscw , much appreciated , it will make it alot easier for him , being that he is 93 yrs old .
Jeff
2pups
Got the mower to cut in reverse for my Dad , thanks for the info Carscw , makes it alot easier for him now . :thumbsup:
Carscw
Glad you got it working for him
