Bolens 38" Deck Engagement Cable Won't Engage
mr_mike_russell
Hi. My 38" Bolens... I installed a new blade engagement cable...When I engage the blades with the lever, its obvious that I am not getting enough tension (springing action) for the blade brake to disengage. Did I buy the wrong part? Is there a diferent able that is 1" shorter that gives me more spring?
The part I bought off Amazon was this:
Deck Engagement Cable fits Yard Machines MTD Bolens Yard Man Replaces 946-04173D 746-04173 946-04173C 946-04173B 746-04173B and 746-04173A​
Thanks. I had originally posted in a different forum, but didn't get more than 1 reply..
Mike
Also if you look at the hole to the lower left it has wear marks and should be where the cable spring goes.
