Absolution
- Aug 4, 2019
- 4
- 13
Hi, I'm usually pretty able to fix and maintain my lawn mowers, but I bought a 38 inch bolens 15.5hp brigs mower that the person said would start but not stay running. I thought that as normal they just had a clogged air filter or something simple...
Thus far I've replaced the Air filter, Cleaned the carb, Changed the fuel solenoid, new spark plug, new spark plug ignition coil, new oil change, new battery, new gas... and I've pretty much ran out of things to replace....
The mower starts, then after a random amount of time will begin to choke, and slowly die, it acts like it's just not getting fuel however if I wait four to five seconds it'll restart while choked and then die shortly after. It sometimes lasts ten minutes other times thirty seconds. I've tried everything I could think of, the only thing that is a remote possibility that I can think up is maybe the exhaust is plugged? I ran it without the air filter assembly and it seemed to push exhaust out the air intake when it died.. I'm beyond confused but I dont want to send the mower off to a scrap heap when it seems to have good compression, and works well while it's running... does anyone have any thoughts?
