bolen rider just quit and wont crank
WR6674
was cutting grass mower cut off and wont crank new battery gas full replaced starter any ideas out there?
I would start by finding (good luck) the fuse. Normally will be located in the area of the battery. Most are the flat type fuses and will be clipped to a body panel/frame piece. If the battery is under the seat then most likely you will need to remove the battery to locate it. Some of the older mowers with the battery under the seat also had the starter solenoid in that area so that would be the general area to look. Same with having the battery under the hood.
