mhavanti
- Oct 12, 2014
- 12
- 924
Also, check for water in fuel.
Another member just had the same problem. Turns out all he needed to do was drain both tanks, let the fuel separate, poor off the gasoline and can then use the fuel. Empty the water out, clean out the tanks, lines and carb.
If this is your problem, you'll be up and running immediately.
Good luck,
Max
Good luck,
Max
