Bobcat by Ransomes model M21-4BZ2C won't start
frisky-maddog
Hello
New to this forum and this is my first question
My dad's Bobcat by Ransomes Model M21-4BZ2C serial number 001760 with a Briggs engine model 096722 type 3202-02 date 870722. 4hp I/C cast irone bore 2 cycle. Will not start. Started fine 4 years ago when he last used it before he had surgery now that he is cleared to mow again this will not start. So far I pulled the gas tank off and emptyed out the old fuel mix (mixed up brand new) and pulled the carb off and cleaned and blew out the carb and put back on but it will not start. I am getting gas to the spark plug (spark plug works in another mower as I tried to make sure it worked) as it does get wet. I also have spark checked by pulling and grounding spark plug to deck with a nice white spark.
What do you have for suggestions to get this back up nd running as dad likes how easy it pushes for trimming. He has self propelled but likes this one better. Says he can move it really easy (which I agree pushes like nothing compared to anything I ever used).
Thanks
