Blowing fuses
Willieksc
Problem solved! After tracing the wiring & putting electrical tape around remotely suspicious looking areas... turns out the PTO switch was bad! I guess it was in the process & caused overloading of the fuse. Go figure! Thanx to all for the responses.
Sent from willieksc using LMF
