Mike Green
- Jun 11, 2016
- 8
Toro 266H Year:1994
Model: 72083 s/n:4901032
Kohler Twin V CV16S
Spec: 61514 S/N: 2408009097
About 900 hours of use.
New Battery
New Clutch
Hi.
My Toro has blown out 2 Voltage Regulators – the original one back in June, and the replacement last month. Each one had a blown diode.
The replacement ran for about 10 hours of cutting - then just died in a field.
Note: The first one blew around the time I changed the clutch if that has any bearing on the situation.
After I replaced the original Regulator, I ensured that I had 14.2 volts across the battery with the clutch OFF.
When I tried to start the mower yesterday, the solenoid chattered. I boosted it and got about an hour of grass cutting. Than it completely died, and would not even “chatter”. The battery was reading 11.5 volts. I guess it ran for about an hour without getting charged.
I have since recharged the battery – it now reads 12.8 volts.
I am concerned that the Toro will blow out the next regulator, so I am trying to figure out what to do.
The problem seems intermittent. No fuses are blown, and there is no apparent bare wires exposed that might short out when vibrated.
Could the the Stator winding under the flywheel intermittently be shorting out when hot? The stator checks out fine when I test it – but what happens after an hour of use later?
It's a 60 mile round trip to my cottage, and there are no tools out there. It's a big deal when it fails.
So 4 questions:
1. What is the typical life expectancy of the Stator?
2. Does it make sense to just go ahead and change the Stator?
3. Any idea what a Stator is worth?
4. Is it a big deal to change?
Any info will be greatly appreciated.
Thanks,
M...
Kohler Twin V CV16S
New Battery
New Clutch
Hi.
So 4 questions:
Thanks,
M...
