Ok guys just bought this used Snapper LE1642H riding mower (older mower). Got it home and went to mow, everything was fine for about the first hour then the blades just stopped. I pushed the PTO in and then back out again and the blades started for about 10 seconds then stopped. I did this 4-5 times more and the blades would engage for a 10 seconds or so and then quit.......So what do you guys think is wrong?? Engine runs just fine and the mower moves under its own power but the blades just won't engage for any length of time
Ok guys let me add a little. I let the mower set for 4 hours. I went out started it up and engaged the electric pto, well it worked as it should. I put it in and out several times and it worked just fine. So it seems the blades (pto) don't work after about 1.5 hours of use, and then if you let it set and cool down for 4 hours or so it works just fine. keep in mind everything else works as it should.
Surely someone out there must have an answer for this or know something, come on guys......need a little help here.
