Blades disengage
Deerlane
Broken wire on trans pedal linkage at right side. Its going to ground and then shuts off PTO.
Joe Williams
That sounds like the clutch is slipping, and so gets way too hot. And as the post above indicates that it is not adjustable, that would mean it probably needs to be replaced. My problem is, it sounds like, electrical, as it can be immediately re-engaged.
hookemtx2525
Coil basically wasnt breathing caked with grass clippings cleaned ot out running great now. Hopefully.
