I have a Craftsman Model 917.272452 42in deck lawn tractor and at the beginning of the season I put on a new set of blades. I did notice after cutting the lawn sometimes didn't just look right to me but went thru all the normal things, check tire pressures, reset the deck, also reset the guide wheels. As I also use the machine for snow blowing I do all the cutting setups at the beginning of the year. So back to the problem ( maybe ). When I removed the blades I saw the odd to me the way they have been cutting. Because of them being new the paint showed how they have been cutting. Seems that some parts are not even cutting because the paint is still on the parts of blades not cutting. These blades seem to have a slight pitch to them so it is hard to tell if they are bent or twisted wrong from the factory. I installed another set of blades but can't tell how they cut because I will have to wait for grass to grow some before I can tell. The set I installed are the original set and have been sharpened. Am downloading pictures : I understand the high spots but if you look to the right of the photos you will see the areas I'm thinking about. Thanks in advance for the help. Picture 1-4 and 2-3 are the pairs
