I have a Walker that lost the gear seal on the bottom side and the gear shaft dropped out of the housing by approx 1/4". I have reseated it but to my dismay...the blades hit in the middle of the deck. I know that I have to re-clock one or the other. Is there an easy way to do this? The gearboxes are the Aluminum ones which will be the standard duty. Thanks in advance!
