Blade nut
Dirtbike88
Hello i hav older snapper 28in single blade with 3 holes. The center nut jus threads on stud mounted to piece blade connects too. Two bolts n nuts tighten down on both side of center nut. I beed know size of nut for center i k o its fine thread and then what type of washers..schematic would b great..thanks
Scrubcadet10
Moderator
Staff member
What's the model number?
The model number and serial number label on a Rear Engine Riding Mower is located on the back frame behind the engine.
The blade bolts to the spindle, You need to GREASE the spindle yearly. There should be a grease fitting below the blade on the spindle. Might be covered in grass. Dig around and see. Also grease the front wheels and rear bearing if yours has one.
The two other outer bolts on the blade are for leveling the long blades. Check yours........
I use a 3/4" socket on my mower blade. Mine is a 33" deck though. Yours could be the same. Put some sockets on yours and see.
