I know this sounds like a dumb question. Does the blade go above or below the spacer? I put the blade below and I have too at 4.5 just to keep from scalping the grass.
One thing I have noticed is the blades are below the bottom of the deck in front and when you turn them to the back, they are about a qtr inch above the bottom of the deck. I have not moved any of the deck adjustments.
