graydog
- Mar 16, 2012
- 8
- 70
I need some help from a good mechanic.
I have a 61" Great Dane Chariot with a Kawasaki 25hp Engine # FH21VB09436. The lower bearing on the clutch that engages the blades has locked up. I removed the bolt that holds the clutch on & had trouble getting the clutch off, but finally got the bottom of the clutch off. There was a lot of rust on the surface where the bearing fit. The bearing was locked up and I cannot get the top part of the clutch to slop off. I suppose it is rusted on also. I tried heating the top part that fits on the pulley (or crankshaft, I can't tell exactly what it fits on) with oxy/acety torch, but had no success. If I could just replace the bearing so I could dis-engage the clutch, I would be back in business,
I don't know why it has rusted so bad, I try to just wipe the mower off with wet rag without wetting it down with water hose.
Please help me get the clutch off or let me know if the bearing can be replaced. Thanks
