Gord Baker
Glad it worked, now go clean the oven!THANKS guys! Oven worked. 350 did not work. 400 worked. Now, ONWARD...through the fog. AND DAMN THE TORPEDOES!
that makes sense. The bearings must free float. Driving them against each other removes the float.Not being able to move the sleeve spacer to the side tells the whole story well and this is almost always certain why the bearings failed .
The bearings were damaged with the first few revolutions when installed at the factory or buy someone that thinks they understand bearing installation but don't .
That spacer is a very necessary part but what the factory or others don;t know that having to press both bearings in will cause an un-due side pre-load on the balls .
Actually only 1 bearing is all that needs to be push fit . The last J D i believe a LA 135 or close to that number , had 1 press and 1 bearing push . The lower bearing was pressed in until the outer race contacted bottom then the top bearing being a push fit seeks it's correct distance when the blade nut is tightened if the outer race is installed a little proud of housing bottom .that makes sense. The bearings must free float. Driving them against each other removes the float.
