Black & Decker CM1836 Electric Lawn Mower Review
Michael Rodriguez
The Black & Decker CM1836 is an electric lawn mower. It is powered by an integrated 36-volt battery system. You can find this model for an average price of $350. Keep reading to learn about some of the features that it offers. ( Read more : Electric lawn mower reviews )
Cutting
The Black & Decker CM1836 lawn mower is equipped with an 18-inch cutting deck. There is also an adjustment knob that you can use to change the height of all of the wheels. You can change the mower's cutting height anywhere between 1.5 and 3.5 inches.
You also have a variety of options when deciding what to do with your grass clippings. The Black & Decker CM1836 is packaged with a rear bag assembly so you can hold your clippings in there. You can also choose to discharge or mulch your clippings.
Power
The Black & Decker CM1836 electric lawn mower is powered by a 36-volt battery system. It provides enough power for you to cut up to 1/3-acre on a single charge. It takes up to 12 hours to charge the battery back to 100%. You can charge it to 60% in just four hours though.
Maintenance
The Black & Decker CM1836 is extremely easy to maintain. There is no gas engine for you to service periodically or have trouble starting. The mower is also easy to store. You can fold it down so that it doesn't take up as much space when it's not in use.
Environment
The Black & Decker CM1836 is also great for the environment. It doesn't have a gas engine so it doesn't pollute the air while you use it.
The Black & Decker CM1836 electric lawn mower offers an 18-inch cutting width. You can also change the cutting height anywhere between 1.5 and 3.5 inches. The 36-volt battery system provides enough power to cut up to 1/3 acre.
PHP:
[PHP]
[/PHP]
