MowerMike
Re: Black & Decker CM 1936 -- "kill bar" doesn't work. Put key in starts up immediat
Interesting ! And, no, that is definitely NOT normal. For sure, that part needs to be replaced, but the question is what caused this to happen. It might actually be a fuse that has blown, and unless the root cause is determined, it will occur again. If the material is aluminum (non-magnetic), then it is probably a fuse. I don't see a fuse or other part shown in the parts list, so it is probably part of the switch assembly.
As to the ohmmeter readings, no reading is the same as OL or infinite resistance, indicating an open circuit. A low reading of ~1 Ohms indicates a closed circuit with some internal resistance from the wiring. From what you have reported, it sounds like your switch is operating normally.
At this point I would recommend purchasing a new switch assembly, and cross your fingers !
Also, you might try posting in the Black&Decker subforum under Equipment by Brand. You may find someone who is more familiar with your specific lawn mower.
Good luck !
Good luck !
