Billy Goat KD512SP - Leaf Vacuum
I will narrow the list down for you. Both the 487170 and the 698444 supercede to the 799868 carb so if you have a primer carb then that is the current part number for all date codes. The 498964 and the 497353 are both obsolete. So if you have a choke carb then not much recourse.
Slight correction 487170 is not a valid number> Typo 498170 valid number as said supersedes.
Tnx IL on the NLA my current price file supplier is no longer listing the supersedes or NLA items. I will flag both PN as -NOS items.
I would had checked but I had to run on a TO35 call to change fuel bowl and filter. Customer shattered the old part and trying to get it of with 3/4" wrench when it takes a 18mm.
