Big dog alpha. What size belt does it use?
Since I’m not standing next to you, looking at the unit, it will be very difficult to say what belt length you need. Yes, belts are expensive, but you don’t want to buy a cheaper belt with the wrong angle. As stated, your best bet is to contact a servicing dealer or contact Big Dog directly. Don’t be penny wise pound stupid.
was wrong! 5/8 x 138. Big Dog is gone! Hustler quit making them.
BBill, get your act together. There are two different numbers because you said you need both belts so MParr gave you numbers for each belt. My suggestion is if you don’t understand this, don’t try to change either belt. Might be in over your head.
I edited the drive belt number. It's 14939.
