H hounddawg Forum Newbie Joined Jul 3, 2014 Messages 4 Oct 25, 2015 #1 BG 86 blower it is not firing.I replaced coil and still wont fire.I removed the switch wires and still no fire.what else is there to do?
D Derek101 Member Joined Oct 13, 2015 Messages 13 Oct 26, 2015 #2 Check key way on flywheel or wires to coil correct.
066 Well-Known Member Joined Oct 18, 2012 Messages 138 Oct 29, 2015 #3 double check that the coil air gap is correct, check that the sparkplug is good & has the correct air gap
