Grekalis
- May 6, 2021
- 1
Perhaps using fiberglass can help you. This material is excellent for closing such holes without the need for welding. Fiberglass is easily attached with glue and you can paint over this material on top so that there are no visible signs of repair. My dad also used fiberglass to repair his benchtop jointer. As a result of long use, the case was damaged and dents formed. My father bought fiberglass and special glue and quickly repaired the damage. After the glue had dried, we decided to repaint the entire tool and it looked like new. I also heard that you can use a metal mesh, but we did not have such material and I can not say anything about how much better it is than fiberglass.
