Hammermechanicman
- Jan 10, 2020
- 69
- 3,905
Southwest Ohio. Long drive from WV if that where you are.
That's not a long drive at all. I used to drive 3 hours, one-way, for literally 60 seconds of fun back when I was skydiving every other weekend.Southwest Ohio. Long drive from WV if that where you are.
If the symptom is the mower seems like it wants to pull the rope out of your hand when you pull it then the flywheel key has sheered.I guess that's the end of that! The 20" Murray push mower a mowing client gave me has a bent shaft. I was fearful of that since it had this weird pull of the rope, like it was "catching on something" and the shaft itself (with blade removed) was very wet with oil. The blade itself looked really good though: no damage, only rust.
With blade off though, it's clear the shaft is not sitting in the center of the shaft tunnel.
I now know what to check first when someone gives me a mower!
I'll continue cleaning up the carb and gas tank...........I already have those off anyway.
Anyone have a good shaft laying around they don't want?
Remove the flywheel nut and you can usually see if the keyway aligns with the key.
This happens because with a sheered key the mower is "out of time" and depends on how bad the crank is out of alignment with the flywheel the mower will fire the piston backwards as it is not sparking at TDC.
Check If the blade is hitting the deck also.
replace the key and tighten the flywheel back on.
Alot of the time when mowers come into my shop with this issue, you replace the key, then start it and the mower will vibrate when it's running.
This is a bent crankshaft, a badly bent crankshaft and the mower will walk around in circles if left to run on concrete.
If it's not too bad mow with it,. eventually you'll tear it up, or replace the crank or have a shop bend it back.
Most shops won't straighten cranks though, special press/tool to do so,.
