interesting. Thank you for the insight. In the years I worked in automotive machining and racing we saw maybe 10,000 heads, mostly water cooled but many air cooled. I never once saw a guide migrate that I can recall, although I have seen them break, and wear out. I suspect from the description given above, carbon build up on the valves may be the culprit that allows the valves to drive the guides towards the keepers. Just guessing. It just seems so common a problem in these threads that the manufacturers should find a fix like putting a snap ring or collar on the valve side to lock it from migration towards the keepers if that is the direction they all go.
The only similarity between auto engines & mower engines is you put petrol in both .
Mower engines are the cheapest nastiest engines that it is possible to make.
Every cheap & nasty cost cutting measure that can be taken and the thing still run has been done.
All of the quality engines have gone so now we are left with nothing but crap .
Some are just higher on the Bristol chart than others
Valve stem migration was a common thing in the motorcycle engines of the 40's & 50's then they learned how to keep them in place
Many auto engines cast the guides into the heads with a flange on them so they can never move ( or be replaced ) as now days worn guided can get sleeved but with the advancement in guide materials worn out valve guides only happen in race engines where you are pushing everything past it's reliability limit or with an abused engine running on filthy oil
I have not been to a mower engine factory but I could almost guarantee that the guides are pressed in then not honed before assembly to cut costs.
This was tried by the Japanese motorcycle factories in the 60's and eventually they got it right but there were a lot of valve train failures in the 60's & 70's till they got it right .
When you are pushing in a finished to size guide the amount of interfearance in the fit is reduced to the minimum that is required to hold the guide in place and modern pressure die casting allows the guide hole to be formed in the casting such that a tiny , or no finish machining is required .
Heat treating is cheaper than machining .
All of this is fine as after all they are just mowers, throw away items designed to go for 5 to 10 years if looked after properly .
Modern computer modeling of heat exchange has allowed cylinders to be cast with the minimum possible number of the shortest possible fins which again saves metal CHEAP, CHEAPER , CHEAPEST & still needs to be Cheaper next year
