belt tensioner for mower deck
Kingman
I reinstalled electric clutch on my 618C Grasshopper and after installing the spring on idler pulley bracket (I didn't remove bracket or pulley) the belts are to loose. the spring doesn't seem to be stretched. the belts don't seem to be worned very bad. Any help would be appreciated.
Two things to check. Either the belt is not routed correctly or the spring is not attached to the correct point.
