Are the drive belt and deck belts the same size? From my research both belts have the same part number which is 144959 (deck belt is 130801). Both numbers are on the exact same size belt. I need to order a deck belt and want to make sure I have the right number.
Also, my bf has a LT2000 and it has the same belt numbers. Is this correct?
Thanks everyone
Thanks everyone
