I have a silver eagle Dixie chopper 07, low hours. It has started not charging the battery. Put new battery in it, it will mow 2-4 hrs and then the negative battery light comes on. After mowing a short time, not exactly sure how long but not long it will just stop! I can charge the battery and it will mow again just fine, but it has became a routine. I charge the battery awhile it mows then stops! Any ideas? Thank you for any suggestions!
