Where would I start to find the problem and where is the voltage regulator.
Jerald1939 Forum Newbie Joined Sep 11, 2014 Threads 2 Messages 3 Sep 22, 2014 / Battery won't charge SLT1554 #1 Where would I start to find the problem and where is the voltage regulator.
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Sep 22, 2014 / Battery won't charge SLT1554 #2 Made by MTD with a Kohler courage engine. Start small, check for bad connections, like battery cables, fuses, loose wires. From there you will need a millivolt meter.
Jerald1939 Forum Newbie Joined Sep 11, 2014 Threads 2 Messages 3 Sep 22, 2014 / Battery won't charge SLT1554 #3 Thanks I will check these items.
