Battery Replacement with bigger one
Greenworks77777
The Greenworkstool lawn mower pro currently uses two batteries: one 4Ah 288Wh 80V Max and one 2Ah 144Wh 80V Max. Can I use two 4Ah batteries instead? (The bay can accommodate two larger batteries. The 4Ah battery is larger in size than the 2Ah battery.)
