My old battery post melted, I bought a new one, I checked voltage that shows 12.07 on the new battery which the instructions said it should be.. battery post is very clean, no corrosion. The negative cable gets so hot it has started melting the cable into the battery. I took the cables loose before the post started melting. Any ideas what i should do
