I-75
- Apr 23, 2013
- 11
- 21
Currrently using a Huskee 21 hp that has a starting issue. I can start the mower but if I turn it off after an hour or two of use and try to start I just get clicks.
If I clean the positive connection it usually starts.
The same thing happens after another hour of mowing (same day/session). The second time this happened I just tuned the bolt a half or so turn and it started back.
So it does not appear the battery if dead but the mower is finicky about when it wants to start.
Positive cable sheathing is slightly exposed at the post connector but wire cable does not appeared frayed.
Thanks for any suggestions.
