I have not found anything on this subject in this forum. Maybe someone has had this problem and can help me. I have a 2009 Scag ZTR Tiger Cub 23 hp Vanguard engine. The battery is not being charged by the engine while running. I have to charge it externally. Once I get it started it will run all day. I also have no display working on my hour meter.
There is voltage going to the hour meter when I turn the key is on and the seat switch is engaged. I checked the hour meter for continuity and it has none. I am assuming (a guess) that the meter is bad. Could this be my problem with the charging of the battery?
