SeniorCitizen
- Aug 28, 2010
- 132
- 2,180
Three... Additional real estate for a short circuit, too!I believe you'll experience the advantage when you attempt to fit a metric wrench on a U.S. nut or a U.S wrench on a metric nut . No trips to the tool box or back to the tool box .
Have you ever had to clean the corrosion from the battery post , screw , nut and cable end ? The C clamp makes it easy . I suppose we could say the advantage of clamps is they serve 2 purposes .
If you happen to have c clamps that will fit the situation , they are excellent for connecting most lawn tractor batteries . Heavy duty are best but your light weights will usually work . These pictured when re-positioned to vertical make excellent handles for lifting and carrying .
But which is worse in salt water, a battery or a shark?Dont forget to go for a quick swim at the beach before picking to the C clamp Battery holders. The Salt Water makes it more fun!
A snark...But which is worse in salt water, a battery or a shark?
