Standard mulitmeter with battery wire connected or disconnected same result. Even with no battery it should show a charge of about 14v dc.
NOT SO
Are you reading the battery voltage or using a ammeter to indicate charge?
What is the part number of the regulator you are using?
(reason I ask is this will tell us what charging system your engine is using)
and we can then give you some logical troubleshooting tips
NOT SO
